WA1 Needle & Seat
Theres someone in the WTN sells a improved version that cures the leakage problem. He always has an ad in the back in the want ads,
Roger0 -
Rodger,
Thank you for the Tip since I overlooked the Ad in the WTN. Chuck0 -
I think I've seen Walt post that those are what he uses in his carb's and he's the carb guy,
Roger0 -
I think his name is Craig. I used them on my Twin H with great results. Daytona Parts Co. has thier own improved needle and seat. They seem to work well. They said the Craig type can become magnatized with use and cause problems. I can't justify that since I think the balls are stainless and the rest of the parts are non ferous , Brass and cast pot metal (zinc?)/ Anyway, I recommend the craig valves.0
I installed the Craig valves about a year and a half ago. Never had an overflow since.0
Me too!0
Guys,
Thank You for the Suppliers Names. I am all set now,
Thanks.
Chuck0
- 112 Hudson 1916 - 1929
