Disk Brake kits , coming soon
faustmb
faustmb Senior Contributor
edited November 2012 in HUDSON
I am excited to announce that the Disk Brake kits previously available from Richard Pridemore will soon again be available. I have been working with Richard to take this service over since he is no longer interested in pursuing it personally. Per Richard, he has sold over 200 kits since he started selling them roughly 10 years ago. I have seen quite a few of them installed, and have only heard positive things from those who have them.
This is a bolt on kit, which requires no welding or machining to install. It is the only one I've seen that includes new hubs and does not require machining OE hubs or modifying the new rotors.
The new kits will include the following items;
-new CNC machined hubs with new studs and lugs nuts
-new laser cut caliper mounts
-new Master Cylinder bracket (bolt in)
-new laser cut wheel spacers (to use OE wheels)
-new rotors, calipers, pads, and hoses
-new wheel bearings
-new hardware as required, grade 8
-comprehensive instructions and replacement parts list
My goal is to order a batch of 5-10 sets early in 2013. I estimate that the sell price will be in the $800 range, depending on how many sets are ordered and the final costs once everything is pulled together.
I would like to gauge interest to get this first order rolling. I am also interested in hearing any feedback from people who have these kits (or others) installed.
Once I have firm pricing and a firm schedule, I'll post something more formal and run an add in the WTN. Meanwhile, please email me with any questions or feedback.
Thanks,
Matt
HETfaustmb@yahoo.com, drop the HET
«1
  • Glowplug
    Glowplug Expert Adviser
    Good on you Matt for taking the initative and the risk. Good Luck with this endeavor.
  • Can you just buy the hubs? I do not want anything but the hubs.
  • rambos_ride
    Hi Matt,
    I bought 2 kits from Richard years ago. He was a great guy to talk with, very knowlegable - love his racing stuff!
    Unfortunately I had to sell both kits when I was on hard times.
    With that parts list 800 doesnt seem too bad and I'd be interested in a kit for the 49 but.....
    Since mine is a custom build..I wouldn't need the master cylinder as I'm not using the stock one anyway.
    In fact, parts like master cylinders, rotors, calipers, pads, hoses..those are all readily and cheaply available at a local parts store or online. Sourcing, shipping and packing costs for these items just adds to your overhead and you obviously have to pass those costs on to your customers...perhaps an optional recommended parts list would suffice..or sell 2 different versions of the kits..one with the Extras..like a Deluxe Package and a Standard Package with only the critical machined parts and just a parts list for the easily had items?
  • faustmb
    Hey guys, I appreciate the feedback. It's good to hear what options you guys are interested in. I have no problem breaking the parts out based on demand, such as hubs. I figure a lot of guys won't need the wheel spacers either, so that can be an option as well as the MC w/ bracket.
    Dan, as far as the purchased parts, I think that makes sense too. However, if I buy 5- 10 sets of hardware I can easily get 10-20% off which allows me to make sure that all the parts are good and have some room to still sell them at counter price. I have no issue selling it either way, but I figure that there will be a demand for a complete kit that doesn't require the purchaser to round up 1/2 dozen other parts and make sure they are correct. It seems like there are so many variations with aftermarket parts that I get burned frequently by a "compatible" thread or otherwise unexpected (or missing) feature in a replacement item.
    I'll make sure to factor these items when I pull pricing together.
    Thanks,
    Matt
  • A lot of folks not in the bussiness world may not understand the quantity discount factor in pricing. But you could maybe come up with a couple different "Packages",
    Roger
  • commodorecollector
    commodorecollector Senior Contributor
    Mat, I would be interested in buying one of these kits in the future when I would modernize one of my Hudsons. However currently all of mine are going to be restored back to stock with their orgional drum brakes.
    Still nice to know that they are available. Thanks for taking the initiative and getting the ball rolling on this.
  • joe53HH
    joe53HH Expert Adviser
    Matt, I have been working (slowly) on my '53 this year replacing the master cylinder and the four wheel cylinders. I may be interested in the kit for a future upgrade though and have a few questions. Is the master cylinder a dual? Does it come with a remote reservoir? Would or should a proportioning valve be needed? Thanks for the information. Joe
  • faustmb
    The master cylinder is a dual, there hasn't been a remote reservoir option but that's a good idea. I'm not clear on the proportioning valve, it has been done both ways and I don't have an official recommendation at the moment.
  • Interested in brake kit also, thanks, Bob P
  • The remote reservoir's are a common HotRod item and are available thru that market. Last I looked you could get them for about $30.00 for a kit,
    Roger
  • Richard E.
    Richard E. Senior Contributor
    I put the Pridemore disc brake conversion on my '50C6 last spring and I put 8,000 miles on the car this summer and I am quite happy with the conversion. I also fitted the car with remote reservoir sold by HET Club member Erwin Sanchez. He makes these for the stock Hudson master cylinder. The problem that I had to overcome is that the new master cylinder, for the conversion, is made to be mounted on the firewall, not below the floorboards. I had to fashion my own top to prevent leakage of the brake fluid. The stock cap leaks like a seive when you feed it from above. It was a little tricky but I have it working just fine now.
  • I've never seen one done but can guess the seal would have to be good around the hose. And If there is a vent in the cap I suppose it would need to be sealed ?
    Roger
  • Too bad that someone or some entity won't invest in something these cars actually NEED, such as gas tanks
  • Richard E.
    RENU works great on gas tanks. I'm sure that there is one in your area!
  • GrimGreaser
    http://rickstanks.com/ has made 46-47 and Stepdown tanks. They're stainless.
  • Ol racer
    Ol racer Senior Contributor
    edited December 2012
    Could someone that has installed the Pridemore Disc Brake Conversion tell me what Master Cylinder was recommend to utilize, or just used the original M/Cyl.
    Thanks
  • faustmb
    Richard definitely does not recommend the original, although some people have used it. It is an 80's model GM unit I believe, but I will confirm once I have the actual numbers in front of me.
  • The Pridemore kit listed a 1980 Chevy Monza MC Napa part #39027 Bendix part #11737
  • Ol racer
    51HornetA
    Thank you for the Master Cylinder Part Numbers. I knew it would need a larger type chamber for calipers.....
    Chuck
  • faustmb
    I would like to hear from anyone who has used these on pre-stepdowns. Bill Labud and Richard both told me that there are guys with their kits installed on 37 to 47 models, but neither were clear on what was required to make it work. Ultimately I would like to offer Kits (or instructions) for these models as well.
  • faustmb
    The shop that made these will be making the next set too. The CNC program is what they have, and they seem good to deal with. I plan to proceed with the kits as Richard designed, but once I have parts in hand I can start to explore this which I agree is a better option. Haven't been on your site in quite awhile, just got too busy. I do appreciate the offer and will take you up on that.
  • Courtesy Man
    Courtesy Man Expert Adviser
    On my 1947 Hudson pick-up I put A-arms from a Hornet on it and so I would think with that alteration which includes the brake drums and spindles that a switch to discs would here be possible. Don't know about the original set-up however. Gert Kristiansen
  • faustmb
    I'm told the caliper plates will bolt on from 37 -up. The new hubs will work as well, but use 1 different wheel bearing. Thats about all I know, but it seems like these older cars with very small drums would be as good or better candidates for brake improvements. Thanks for the info,
  • coverton
    coverton Expert Adviser
    Is anyone building or should say fabricating a trapeeze brake kit for hudson ? would be nice to have a pwr booster n master cyl on the firewall
  • Ol racer
    Regarding Front Brake Interchange ...
    Step Down Hornet backing plates & drums will bolt right onto '37 front spindles. However one Wheel Brg does need to be utilized from the '37 hub. Additionally, Stepdown Hubs Inner dimension between races are 1/8" narrower (or the '37 Spindle is 1/8" longer) requiring an additional 'washer' inside the castle nut. I obtained a 'hardened washer' at Lowes to utilize. Therefore I expect Large Stepdown Brakes to fit right onto a '41-'47 Hudson as well... So Disc Brake Kit Brackets should bolt right onto the older Spindles & Hubs (back to '37) anyway by interchanging the one W/BrgThere is a 'St Rod Company' making Under Floor Power Booster Master Cyl Kits..... However, Im thinking of fabricating a Bracket under my Stepdown to bolt a dual Master Cyl up to the Hudson adjustable pushrod.
    A few Yrs ago I bolted aTorino dual M/Cyl up to my stock '46 pedal assy that works very well. Regarding a Remote Fill, after brakes were bleed never needed to add fluid.
  • Would be nice to have dual master for a stepdown and keep the backup system and emergency brake setup. And dont let anyone tell you that with dual system you cant loose brakes completely. Ive had it happen,(73 Chrysler )
    Roger
  • faustmb
    Richards design includes a dual Master are retains the factory rear brake. I am looking at some other options as well that include remote firewall mounted reservoir.
  • Excellent ..................
  • JasonNC
    JasonNC Expert Adviser
    When I was interested in getting a kit from Richard, he advised that this kit was designed for automatics and that it would have to be modified for a straight drive car. I lost interest at that point even though I would like to have disc brakes so I can take the old girl back on a mountain trip without getting the hell scared out of me.
  • Ol racer
    Glad to see Interest in building Disc Brake Kits again...I cant think of a reason the Kit & M/Cyl upgrade wouldnt work on a Standard though....
