wheel covers
wanderer23464yahoocom
Did the trucks have wheel covers? If so what fits this wheel. No little clips like on the cars.
Looks like a Ford Wheel someone drilled for the pin.
Chrysler and Studebaker also fit.
It did have the Wheels with clips originaly0 -
Yes , had the same 16" wheel as the car, so could have any Hudson hub cap you want, (46-47)
Roger
Looks like the sort of thing Paul (out in WV) or Alex (out in Waterford) would have hanging around in an outbuilding somewhere. To save yourself gasoline, though, you may want to come up with a list of all this needed stuff before you head out to rummage around! Looks like the previous owner did a lot of "mix and match"ing of parts!0
Open the other atatchment if you can its a dealer info page for the pick up,
Roger0 -
Yup, Hudson wheels have..or had, the clips. I'm using a set of 15 in wheels and Hubcaps from a wrecked 37 car I got from a Mr. Davidchuck that Jon B. had met and remembered (Name and address) from 20 years earlier, in Broadalbin, NY. They clearly say 'Hudson' for the great unwashed that doesn't know.0
I don't see the dealer info pack for the pick-up? Or is it just the sales brocure you are refering to?
Yes , it was part of a booklet , I guess only part came up . Ill see if I can get the rest to post.0
I only get 25% of each page, upper left corner.
Lee O'Dell0 -
I dont know why that would be Lee, They work when I do it with my computor. I guess the settings must be different someplace. I can email them to you if you like or I can print them and mail you a copy ,
Roger0 -
Roger
I just tried it again and same thing. I would appreciate copies if you won't mind mailing them. My printer is not working. I'll add this info to my PU information folder. Let me know how much IOU for mailing.
Thank you for the offer.
Lee O'Dell
I could'nt find that , I did find you in the HET rouster in Burbank .Is that still good?
Roger0 -
Sorry I didn't add address Roger. My roster address is correct.
Lee
...............................................................................................................................................................................................................................0 -
I've replaced some with screws and nuts. Heavy duty pop rivets will also work.0
OK , I'll send out a copy.
Roger0 -
On my car, I took the clips off a wheel that was laying around and spot welded them in place. Works great.0
Leather ? ...............
Roger0
