Many thanks to all that helped!
Took the 37 out for it's first test drive, fingers crossed!! Most all went well!
Ran well, shifted well. Need to check my brake light again, stopped working, and the speedo doesn't work, suspect cable related. Tweak out a few things and should be good to go!
It's been quite a project, came to me in boxes, buckets and cans. Parts of 4 or 5 Hudsons to make this one! A lot of help from Hudsonites on this board and others or I couldn't have done it!
Many Many thanks-------
Congrats on your maiden voyage.
Any pictures to share?0 -
I have close to a thousand pictures of the build process. I will work on a condensed album this weekend and post the link.0
I think that brake switch can be pryed apart, cleaned and will work again. Did that to my 360
I took it apart but one of the holes that the wire connector comes up out of was eaten out. I had a good starter switch, has the same plastic housing and switched the housings out. It was working good, so I just need to check it and make sure the switch is ok then trace back to light.
Condensed picture album, will add a few more later-
http://s294.photobucket.com/albums/mm97/studebaker2/1937 Hudson Terraplane Restoration/
Holy Cow, great job. I like the color. Thanks for sharing.
Gene.0 -
Gene.
Yeah, what Gene said!!!
Kevin C.0 -
Ya think this broken down piece of junk will make it to the winter Meet?
seriously, I think Diane is going to be blown away !!!!!!...Maybe so enthused, she runs for pres of the OBC ?0 -
Fantastic - that's going to be awesome.
Alex Burr
Memphis, TN
Thanks guys, it's been a heck of an experience!
Dave, Diane is in very poor health, some of the club members may want to touch base with her, she has been having a rough time.0 -
Wow! You did an incredible job! Thanks for sharing. Michel0
- 112 Hudson 1916 - 1929
