Hudson Hood Emblem Wire Clip Locations
commodorecollector
commodorecollector Senior Contributor
edited December 2012 in HUDSON
Hi,
Could someone please post a picture of a 1949 Hudson hood (1948-1950 should work too I assume since the design did not change) showing the inside and the location of the clips. I would like to have it as reference since, one of mine came off when I was removing the emblem and I do not know its proper location.
Thanks,
Chris
  • I'm not sure I understand what cilp's you mean. The 48-49 had a die cast ornament that mounted with bolts treaded in from the bottom. No clips ,just bolt and lock washer ,I can post a photo if you like but thats what it will show,
    Roger
  • commodorecollector
    I am referring to this emblem on the front of the hood, and the wires running to the the light behind the emblem held up against the hood using clips/tabs.
  • Ok , Sorry . I know what you mean now . However that is also bolted it , wire runs down the drivers side of hood lip to cowl. I can get some photos for you tommorow,
    Roger
    Awesome! Thank you Roger! :D
  • No problem - got a 1950 in the shop right now with the hood up,
    Roger
  • Well here is a 1950 underside of the hood -back side of the area in question. Also the path the wire folows to the firewall. Hope this helps you in your resto,
    Roger
