Exhaust manifold ID?
This was a common practice with Hudson, where the number on the casting does not correspond with the actual part number. Is your manifold a twin or single carb model? The twin carb manifold is # 3076050
This was a common practice with Hudson, where the number on the casting does not correspond with the actual part number. Is your manifold a twin or single carb model? The twin carb manifold is # 307605.
It's setting in the garage and I trial fitted it to a twin intake manifold casting 307093 I had laying around and the studs match.
Lee O'Dell
I just went to the garage to see if the exhaust elbow would fit. It does not, the stud spacing between the exhaust manifold and elbow holes are way off by about 1/2 inch.0 -
I'll check that Ken. I also have a 55-56 Twin H intake.
I took another trip to the garage and the holes for the studs in the 55-56 are in a different location. This exhaust manifold will not mount to a 55-56 manifold. Where it will attach to a 51-54 Twin H manifold
Something else I see that is different in this manifold is that the exit ports are about an inch or more lower than the 55-56 manifold and the divider bar exiting the exhaust manifold is flush with the gasket surface as if gasket material should be there also.0
- 112 Hudson 1916 - 1929
