1928 hudson
[Deleted User]
edited January 2013 in HUDSON
Looking for kingpin set for 1928 hudson landau
Have movement when pushing the tops of the wheels in & out but the bearings are tight
  • StillOutThere
    StillOutThere Expert Adviser
    Murphy Landau Sedan? NICE.
    I thought Rare Parts in California might have them but checked the online catalog and they do not. Someone here will know.
  • Jon B
    Jon B Administrator
    Have you tried Dave Kostansek or Carl Weber? (Generally, they advertise in the WTN.) If they don't have the part, they may know of an interchange that will work. Both are acquainted with the older Hudsons.
  • bent metal
    bent metal Senior Contributor
    Still Out There, I think your statement is a little misleading. Maybe more correct to say "Murphy designed Landau Sedan".
    So not to be confused with the "Murphy built Landau Sedan". ....Right? :)
  • oldhudsons
    oldhudsons Senior Contributor
    the body style is irrelevant, chassis same for all exc. long w.b. models where just longer, but king pins the same
  • essexcoupe3131
    essexcoupe3131 Senior Contributor
    edited January 2013
    David or Geoff, should be able to point you in the right direction, to get these
    Mike
  • oldhudsons
    try Egge Machine in L.A.
