Outside Rearview Mirrors for a '50
I have a '50 Commodore 6, and I bought mine from K-Gap.0
I got a 50 commodore 6, I got mine from Mr. Paul Schuster.
might be the same ones that K-GAP sells?0 -
I bought the kind that install on the door frame...Never again..The one on the passenger side is Impossible to position so that it can be seen from the drivers seat...
Make sure that what ever you get you can view BOTH (If you are installing 2) can be used when you are seated behind the wheel....0 -
i SELL TOP QUALITY OUTSIDE REARVIEW MIRRORS, SAME ROUND SIZE AS ORIGINAL SLIGHTLY DIFFERENT BASE, BUT HAVE BEEN USING THEM ON ALL MY STEPDOWNS AND HAVE SOLD HUNDREDS WITH NO COMPLAINTS, COME WITH RUBBER BASE GASKET AND MOUNTING SCREWS AT 30 EACH FIT BOTH SIDES, 60 PER PAIR PLUS SIPPING, BILL ALBRIGHTS VINTAGE COACH 16593 ARROW BL, FONTANA, CA, 923350
I bought a pair from Bill Albright. They look nearly identical to the originals and are quite handsome. Highly recommended. Make sure you mount them properly. Bill can provide exact position. The are door mounted below the window.
Russell0
