Looking for 37 Terraplane stuff
frank spring
I could use a complete engine for a 37 Terraplane, also bumpers. I know this isn't a huge readership, and I can put an ad in the WHITE TRIANGLE, but I thought I would start here.
http://york.craigslist.org/pts/3468129049.html
Here is a Hood,
How about posting a pic of your Terraplane?0 -
A fair amount of 37 stuff shows up on ebay. Not long ago someone parted out a decent and complete 37 right down to the nuts and bolts.0
What would you like? I've got a couple of grills, bumpetettes, trim , a few gauges, an electric hand shift etc.etc.0
Hmm? ....Did you buy the delivery truck? :-?0
Did you find what you were looking for? When I wanted a 34T block, I took the advice from this forum and looked on a hot-rodder's forum. I found the 35 block here in California, which is now rebuilt and ready to go back in the car.
I had looked for a 36 block as an alternative and bought two 1937T engines from this same source (one has a hole in the side, but the two of them should make one good complete engine). Let me know if you don't find what you want - I should be sure of the 35 block in a few weeks. If the 35 works out, then I'll get rid of the 37s.0 -
Have not located yet. Thank you.0
I have a 37 Terra out back..all the running gear and most of the motor. I'm in N central MN 55775 Todd 218-208-20800
This is a lonnnnng way from Indiana, but if you get desperate....
"1937 Hudson 6 cylinder - have motor and transmission - other parts too, North
Plains, Oregon ph 503 396 3542"
- 112 Hudson 1916 - 1929
