Stepdown rims
drivergo2
drivergo2 Expert Adviser
edited February 2013 in HUDSON
Are stepdown rims marked in anyway to tell if they are hudson, Are they stamped hudson or anything. Thanks JOHN
  • The area that is sometimes stamped is on the outside flat area where a tube would go up against. It is marked upon occasion 'Motor Wheel Corporation' - not much help. The thing that may help you are the design of the smaller wheel cover retaining clips. Nash, Kaiser and Hudson all shared the same clips. Providing the are the same diameter and width, they will all interchange as well..
  • drivergo2
    Thanks you guys for the help, John
  • RL Chilton
    Lance and Rick-
    That's fantastic information, guys. Thanks for posting.
  • SuperDave
    SuperDave Senior Contributor
    So where would a guy go to find new hubcap clips for the stepdown? I found a great wheel with 5 broken clips.
  • [Deleted User]
    Andy Bernbaum, a Mopar supplier out of MA.
    oldmoparts.com
  • 48Sed
    48Sed Senior Contributor
    I was told one of my stepdown rims was a 1940's Chrysler rim with a safety step built into it to keep the bead in place during a blowout.
    My Hudson rim has no step and is smooth which allows the use of a beauty ring.
    Both rims were made by the 'Motor Wheel Corporation'
    Any thoughts on this
  • 53jetman
    53jetman Senior Contributor
    Each auto manufacturer had their own specs that Motor Wheel was more than happy to comply with - for a price!
