Dirt Guard Question.
[Deleted User]
edited February 2013 in HUDSON
Attached is a picture of the dirt guard for the master cylinder on my 52 HH does anyone have a picture of what it should look like and an idea of the size, also what is it made of. Thanks for your heip.
  • The material itself was called 'tuff' (really). A nasty rubber and ? mix.
  • Was that simmilar to the flaps in the fender well ?
    Roger
  • Yes simmilar material, I would like to see a pic. and find out where to get close material.
  • Mudflap material.
  • Walt-LA
    Walt-LA Senior Contributor
    The Rubber House has a similar material - fabric laminated in black rubber- a bit over 1/8 inch in thickness. WALT-LA
  • drdoug
    drdoug Senior Contributor
    We have these already made at Wildrick rubber parts
  • Park_W
    Park_W Senior Contributor
    Doug, any estimate on when you'll have an on-line catalog up and running?
  • Does anyone have the dimensions the flap should be.
  • thaidude
    thaidude Member
    edited January 2019
    I have used bits of conveyor belt material for this as well as the rear "mud flap' on 51's and the small piece that connects the strut member from fire wall to the frame. Conveyor belts come in every size and shape an exact replacement is available.
  • I bought one of Ken U’s repro master cylinder flaps for my 51 and it fit and looks like original. He also has the brass fitting and copper washers for the rear of the master cylinder.
  • Uncle Josh
    Uncle Josh Senior Contributor
    Contact Ken at xxxKNNU21@yahoo.com w/o the xxx
