Banjo steering wheels.
Not sure what year your car is that you would like to fit a banjo steering wheel to, but, Hudson did use them in the early and mid 30's. You might contact Grand and see if their various adapter kits would work.0
Wow, what a great looking wheel and dash. My car is a 1950 Pacenaker. The stock wheel is all cracked to pieces.0
I think the hudson shaft spline is the same as 49-56 Ford F100. a 11/16 40 spline. I would consider a used 30's hudson wheel before a Grant aftermarket, even if its a little roughed up. I like the Large 17 or 18" diameter Banjo wheels vs. the 15".0
The earliest Hudson or Terraplane banjo wheels were 1936.0
Up to 1936 wheels had a woodruff key to locate them on the shaft,. After that they were splined.0
Last banjo wheel was '39, I believe. And that's a rare bird indeed.0
Thanks for the info guys.0
- 112 Hudson 1916 - 1929
