Dirt Guard Question.
The material itself was called 'tuff' (really). A nasty rubber and ? mix.0
Was that simmilar to the flaps in the fender well ?
Roger0 -
Yes simmilar material, I would like to see a pic. and find out where to get close material.0
Mudflap material.0
The Rubber House has a similar material - fabric laminated in black rubber- a bit over 1/8 inch in thickness. WALT-LA0
We have these already made at Wildrick rubber parts0
Doug, any estimate on when you'll have an on-line catalog up and running?0
Does anyone have the dimensions the flap should be.0
I have used bits of conveyor belt material for this as well as the rear "mud flap' on 51's and the small piece that connects the strut member from fire wall to the frame. Conveyor belts come in every size and shape an exact replacement is available.0
I bought one of Ken U’s repro master cylinder flaps for my 51 and it fit and looks like original. He also has the brass fitting and copper washers for the rear of the master cylinder.0
Contact Ken at xxxKNNU21@yahoo.com w/o the xxx
- 112 Hudson 1916 - 1929
