Parting out a couple of 54 Hornets
Don,
Any exhaust manifolds?0 -
56 starfire, you will need both the intake and the exhaust.0
weather finally cleared today and I was able to pull a few of the parts off before it got dark. I will get some more stuff tomorrow and start sending them out this weekend.......hold tight0
Hi Don, I need the cast iron ring gear carrier from a 3.07 ratio rear end, the one used with late 52 to 54 Hydramatic equiped cars. The rears had the removable rear cover and come out somewhat easy after pulling the axles. Bruce0
Bruce. These were 3 w/OD cars. Probably a 4.11 rear, but I will look0
I need a front seat bottom and back frame for a 51 stepdown if you have one.0
