Rubber grommets
John , What model Hudson? If you mean stepdown, then there is no 'grommet" on the gas pedal. They have a bellows type boot attaching to a ring that is screwed to the trans floor cover.0
I think he means the big bushing the wires go thru . The best guess would be it is a Hudson part ,I dont rcal seeing one like it anywhere else .And cant recall seeing it reproduced ,I also can sell all the used ones I find - thats another indication thier not around .
Roger0 -
Try good old http://www.restorationspecialties.com/ online catalog. Lots of grommets.0
Also plenty of grommets at mcmastercarr.com0
Thanks you guy for the info. Will check with the both of them. John0
HARBOR FRIGHT ALSO HAS A PLASTIC BOX FULL DIFFERENT SIZES FOR AROUND $70
