headlight reflector refurb advice
Silver plating has always been the preferred method for most reflected light. However there maybe a more modern substitute.0
Don't chrome them. It is nowhere as reflective as resilvering.
The original way would have been silverplating and that is what I did, about 10 years ago. It's held up pretty well, no tarnishing found whenever I've removed the lens to replace a lamp. Eventually, though, they'll tarnish -- just like they did originally.
However, there is a "new, improved" way to do it. A company called Uvira, out on the west coast, applies a glass coating to your reflectors once they have been plated, and this seals in the plating for good. They supposedly will never tarnish. You, however, have to have the reflectors nickel plated and polished first, then send them to Uvira. I'm told Uvira charges about $75 a pair to have the reflectors glass-sealed, and that is on top of whatever it costs to have them nickel plated.
Uvira Inc.
Attn: Mr. Bill Atwood
310 Pleasant Valley Road
Merlin, OR 97532-8871
(541) 474-5050
If you want to have them simply silver plated and be done with it (as I did), it's a bit simpler (knowing full well that you may have to go through this again in 20 or 30 years). You could try a local trophy shop just for fun, but if you google headlight reflector resilvering you'll probably find some companies. I have seen quotes of $75 per reflector, but the place that did mine (maybe 10 years ago) charged only about $55 total, and that included shipping. The fellow's name was Craig Riker (in Toledo, Ohio) and I think the number is 419-290-4442 so you could ask if he still does resilvering and what the price would be for a couple reflectors. Anyway, look around.0 -
I had '33 ET8 reflectors done by Uvira 30 years ago and my most recent pics of the car show they are still brilliant. The car actually lit the road with 6V. WORTH IT.0
Thanks for the advice guys, I will certainly look around and check into that Uvira.0
- 112 Hudson 1916 - 1929
