Radiator swap
Hudsonrules
edited March 2013 in HUDSON
What radiator has people used in a '41-'48 Hudson when the engine was sawped to a small block Chevy? Thanks, Arnie in Nevada.
  • One radiator that will work is a 41-47 straight eight radiator.
  • I put a small block ford engine in a 47 Pickup. Had the filler neck changed to fit a modern pressure cap and the lower outlet modified. It was a 41-47 8 radiator. Worked perfectly here in the Florida heat.
