Essex Terraplane 8 head stud question
I can't imagine water getting by/around the threads in the block so I'd suspect the head gasket is leaking. Have you removed the head & used a new gasket? If not you could retorque the nuts or remove the nuts, clean the threads & use a good lubricant on the top of the studs, perhaps replace the nuts with new ones, then retorque the head to see if that stops the seepage. That is not a common occurence with the old 8s, a common one with the much higher compression Hornets.0
I believe some of those studs go into the water jacket and would recomend sealer on the threads,
Roger0 -
I had issues with the manifold studs but none with the head.0
Had this issue also. new 1/2 head bolts and tapping out the block got rid of the weeping at the bolt holes of the studs. Did not have to seal up the head bolts with sealer as the fit was then as it should be,only used anti stick goop with a cooper base to help keep the bolts and holes from rust up from with in. It is known that the stock head bolts are too small and 65ft.lbs tork is not enough??0
Don't want to steer you wrong, my engine was a 308.0
Your '33 definitely has threaded holes right through to the water jacket. The studs are normally screwed right down to the end of the thread until they are tight. It would also pay to use some sealant on the threads as well. And don't tighten down to any more than 45 pounds, those old 8 cylinder blocks are not too robust.0
As far as I remember it goes right through to the water jacket but I was not sure so thanks for confirming. Is there any sealant you would recommend ?
I can get Loctite 577 here and it goes from -60°F up to 300°F (-50/+150°C), should be OK or not ??
It's only seeping a little around some nuts and the headgasked looks fine. I will anyway install a new headgasket and would like to get rid of this problem in one shot...
Loctite 518 Master Gasket is a good one to use, as it seals with the exclusion of air, as when the studs are drawn down tight. I'm not familiar with 577 but you should be able to check the specifications of it somewhere. Paint the head gasket with aluminum paint and let it set semi-hard ( just hard enough so you can dig your fingernail into it) before you install. Good luck,
Geoff0
- 112 Hudson 1916 - 1929
