34/35 Terraplane Buckets on E-bay?
Are these really 34/35 Terraplane headlight buckets? They don't look correct to me.
http://www.ebay.com/itm/Hudson-Terraplane-Head-Lamp-Buckets-1934-35-/400436317314?_trksid=p2045573.m2042&_trkparms=aid=111000&algo=REC.CURRENT&ao=1&asc=27&meid=6339561065150937144&pid=100033&prg=1011&rk=1&sd=400436317314&
Could be '35. Definitely not '340
they look like depress beam headlights from a '35 with a sealed beam headlight conversion. regards, tom0
actually they are '36 with the sealed beam conversion, they also look like compost!0
Hmmm. My 36 Terra headlight buckets only have 4 rivets holding the base plate where the eaby item has 6. Also, only two holes underneath - one for the reflector tightening screw the other for water. The ones on ebay have four holes! My guess is that they are not Hudson or Terraplane. Regards Phil
They don't look like the one's on my 35 pickup0
I took a chance and bought the buckets off Ebay and was quite suprised by the condition they were in. They looked pretty bad in the pictures, but when I received them, I was suprised to find they had no rust or dents. The rings need a little work, but other than that, they need nothing but a good sanding and paint.0
- 112 Hudson 1916 - 1929
