NEXT: 12" wipers hang up on the W/S trim
Roger Harmon
Roger Harmon Expert Adviser
edited March 2013 in HUDSON
My wipers are hanging up on the top stainless trim strip as they go by. Does anyone have a cure?
R/ Roger
  • Jon B
    Jon B Administrator
    Shorter blade?
  • Roger Harmon
    Does somebody make an 11"?
  • onerare39
    edited March 2013
    Try, Ficken Wiper Service
    wiperman.com
  • RonS
    RonS Senior Contributor
    edited March 2013
    Trico rb 11 (with J hook mount) were the original blades on the 54 stepdowns which was a change from the 1948-1953 RB10. The 54 had a larger windshield of course. Rb 11 was used on 1950 -52 Cadillac & early Vettes. Ebay has 'em on occasions. I have a NOS set of original RB 12 which are exactly 12 inchs. I was going to bring them to San Mateo along with new Anco 11inch blades, that fit the Trico Arms. Measure the length of the blades on your car. If more then 11" it's too much. Ron
  • nick s
    nick s Senior Contributor
    i was thinking RB11 is correct for 54. also roger you didn't state the application but if 12 is correct, is your blade path such that you can shorten the arms as many are adjustable.
  • RonS
    edited March 2013
    Your right Nick the 11 inch for the 54s. 55 uses 12" I corrected the reply.
  • Roger Harmon
    Ficken Wiper Service to the rescue! The correct 11" blade assemblies are in the mail.
    Anyone need some good, lightly used 12" wiper blades?
    R/ Roger.
  • J Spencer
    J Spencer Expert Adviser
    Original size was 10" Available at most auto parts stores. Advance Auto Parts has them available Trico Classic Series# 33- 101 (10') You may be able to use an 11" blade?? I work at Advance and have these on my Pacemaker, about 8 bucks apiece..
    Jim Spencer
    WNY/Ontario chapter
