Almost free cam bearings one third set 1933-37
Courtesy Man
I have two cam bearings NOS marked 160330. But I only have (two) the third smaller bearing, none of the other two required for a set. They feel heavier than alum. but they are not babbit on bronze backing. Anyway if you are needing to have a set machined then here is 33% less to be done. Pay shipping at $5.20 and I will send you - two of you - one. Please reply here as I can't seem to do the PM thing. First come first served. Gert Kristiansen
Forgot to mention that these are for the 6 cyl and have the inside (2) oil grooves. No through hole - were they not staked into the block ? Perhaps you provide that ?0
What are the sizes of the inside diameter and outside diameter?
Thanks,
Ivan0 -
OD 1.752 ID 1.5030
Gert,
These will work for the last journal on my Hudson 8 cams. How do I send the $5.20 to you?
I would like to have them.
Ivan0 -
Hi Ivan - email me at HETgtkristi@copper.net Gert0
- 109 Hudson 1916 - 1929
- 176 The Flathead Forum
