New Timing Chain Gears in Making
[Deleted User]
edited May 2013 in HUDSON
Going to try to attach a picture of new timing chain gear we are having made. Used to make an adapter for our timing chain kits. Now it will be one piece gear.
Randy Maas
  • Randy, does the gear have the offset bushings to allow advance and retarding the chain?
  • The Crank Gear has three keys 0 +4 -4 Also have crank gears +2,4,6,8
    Very easy to adjust to suit your needs.
    Rand
  • Randy, are these for the stepdown engines or the splashers?
  • Thanks Ken. I was hoping it was a roller chain replacement for the splasher gears
  • I'm curious about Smokey's backward running motor ,tell us more
    Roger :)]
  • You're dead right there Ken, I've had a serious brain fart.
