1951 door rubbers
I need to replace all the door seal rubbers. I have found Metro Rubbers catalog but am unsure in knowing which pieces i need. For example my car has three different rubbers running across the top of the door openings, leaving me unsure as to which one is correct, and then unsure as to which one i need to buy. Metro have two rubbers LP-40 and LP-40A which are the same except one is heavy duty. Are these to go across the top of the door opening, and perhaps also along the leading edge of the door? Does anyone know which of these works better or if someone has a complete kit?
Simply call Wildrick Rubber Parts at 317-398-4163 and not only can you get precisely what you need, but the boys at WRP will assist you in the knowledge of installation. There couldn't be a simpler, easier rubber supplier than our own Hudson guys.
If you call on M,W or F, ask for Dennis. Tell him I sent 'ya.0
