1936 Terraplane hubcap needed (FULL SIZE)
I would like to know if any one has one of these they are willing to part with I have already checked with Jason and he dose not have any so I thought I would ask here before I put an ad in the WTN. I am looking for a 1936 Terraplane (FULL SIZE) wheel cover that says Terraplane on it not the (LITTLE ONES) I sent four of them out to be restored and one of them is no good that is why I am looking for one so please check your walls and see if you have any of these hens teeth thanks.
Wow, I thought the full covers were only for the Hudsons! You learn something new every day.0
FWIW heres a photo of a full size 36 H8 hubcap. I've got 2, I need to either get 2 more or sell these, preferably the former.
If there is a Hudson Eight and a Terraplane version of these full size caps, presumably there is also a Hudson version for the sixes?0 -
Never saw a Terraplane full wheel cover. I'd like to see a Photo.0
I have never seen a Terraplane one either, never had them Down Under.
If cost is no object, it can be restored. The ones that I have done run between three and four hundred to do one. If you cannot find one let me know.. PM Me.0
They look like this. I have one only.0
Just goes to show, you learn something new every day, in my 55 years of being around Hudson/Terraplane cars I have never seen one.0
Thanks for the post , a first for me also.0
StillOutThere I sent you a pm if you did not get it would you please call me (651)315-1337 thanks Tom.0
I have a set of '36 Hudson Eight ones. From what I can see it looks like a composite with the standard hubcap surrounded by the larger disc around the outside.0
Rocket is purchasing my wheel cover above.0
That's probably a good thing, as it sounds like this is not really a readily available item!
>- 0 -
A vintage car parts shop here in Adelaide South Australia has several 1933 hub caps for sale, and also a mid 30s full size hubcap with the words Hudson8 on it. ozhudson@gmail.com0
- 112 Hudson 1916 - 1929
