46 hudson truck tires & wheel question
My question is: are the rims ( 6.50/16) on a 46 Hudson truck welded? I would like to put tubless tires on the truck.
It has tubes and liners on it now, as the valve stem comes strait threw.
Did Hudson ever use tubless tires?
What tires do you guys recomend?
Thanks, I will post pics very soon, as I am going to fetch it this week end!
I've dealt with Rally America. An example of how a business should be run.
Flawless communication.0 -
so... I can, or can't put tubless tires on 46 stock rim's?0
Got It. so its in the design of the rim, not the fact that the rim is welded and air tight.
Thank you all0 -
ON MY 57 I HAVE TUBELESS TIRES ON THE ORIGNAL WHEELS I HAVE BEEN RUNNING THEM THE BETTER PART OF 40 YEARS I HAVE NEVER HAD AND TROUBLE AT ALL I DRIVE THE CAR FAST 75 TO 80 ALL THE TIMES AND A FEW TIME OVER 100 I HAD THEM SPUN BALLANCED I HAVE HAD RADIALS ON IT AS WELL AS BIAS PLY TIRES WITH OUT AND PROBLEMS LIKE I SAID0
I am finding all this very helpfull, but I still don't know what to do.
I am after a stock/original looking tire, but with modern convenience's and good wear. I plan on using this truck as a daily drive ( after I get it all sorted).
46 HudsonPU, from what you are saying, If I follow you right, I will be OK as long as I get a tire
that matches my rim size ( It might not be a 6.50" or 235)
am I correct?0 -
RICK :THE RIMS ON THE 57 ARE 6 1/2 '' RIMS AND A 800X14 TIRE WORKS GREAT
paulrhd29nz : RADIALS TAKE A LOT MORE EFFORT TO STEER WHEN PULLING TO A PARKING SPACE ( the foot print is larger) some thing to think about0 -
With radials you need "Armstrong Steering".
Kevin C.0 -
15 " rims were an option ? I think the cars had option in 47 , not sure of trucks.0 -
According to info in my file, Hudson trucks only had one wheeltire available - 6,50 x 160
I just got some 1947 material from Ric Pinder - among that material is a 1947 Price, Equipment and Option folder. 53Jetman is correct - trucks used 16 x 6.50 six ply tires. There are three colors listed: Ebony Black (K) w/cream wheels; Gun Metal (G( w/Red Wheeks; and Blevedere Blue w/cream wheels.
Anybody wishing a copy of this folder drop me an email and I'll get it scanned in a few days and email you a copy.
Alex Burr
Memphis, TN
NEChudsontech09@yahoo.com (Drop the NEC)0 -
Riveted rims "might leak", welded ones usually don't . I've run tubeless tires on all my stepdowns that had riveted wheels with no problems. Been doing it since the seventies. If you are going to do some heavy high speed driving and cornering, perhaps a newer rim is a good idea, but under normal use.. Use your stock rims and the tubeless tires.0
If you go tubeless just make sure the inside lip of the rim is clean and no rust pitting to prevent loss of air pressure.
Lee O'Dell0 -
The rim size is not given.
Alex Burr
Memphis, TN0 -
The brochure is interesting, even tho the info is also available in the shop manual. This brochure was issued to salesmen (and marked for confidential use) to help them sell cars - and trucks. Lot easier for salesmen to tuck in their pockets - shop manual would be a little bulky.
Alex Burr
Memphis, TN0
- 112 Hudson 1916 - 1929
