1936 Terraplane hubcap needed (FULL SIZE)
Rocket
edited June 2013 in HUDSON
I would like to know if any one has one of these they are willing to part with I have already checked with Jason and he dose not have any so I thought I would ask here before I put an ad in the WTN. I am looking for a 1936 Terraplane (FULL SIZE) wheel cover that says Terraplane on it not the (LITTLE ONES) I sent four of them out to be restored and one of them is no good that is why I am looking for one so please check your walls and see if you have any of these hens teeth thanks.
  • Wow, I thought the full covers were only for the Hudsons! You learn something new every day.
  • bob ward
    edited June 2013
    FWIW heres a photo of a full size 36 H8 hubcap. I've got 2, I need to either get 2 more or sell these, preferably the former.
    If there is a Hudson Eight and a Terraplane version of these full size caps, presumably there is also a Hudson version for the sixes?
  • Never saw a Terraplane full wheel cover. I'd like to see a Photo.
  • I have never seen a Terraplane one either, never had them Down Under.
  • If cost is no object, it can be restored. The ones that I have done run between three and four hundred to do one. If you cannot find one let me know.. PM Me.
  • They look like this. I have one only.
  • Just goes to show, you learn something new every day, in my 55 years of being around Hudson/Terraplane cars I have never seen one.
  • Thanks for the post , a first for me also.
  • StillOutThere I sent you a pm if you did not get it would you please call me (651)315-1337 thanks Tom.
  • I have a set of '36 Hudson Eight ones. From what I can see it looks like a composite with the standard hubcap surrounded by the larger disc around the outside.
  • Rocket is purchasing my wheel cover above.
  • That's probably a good thing, as it sounds like this is not really a readily available item! :)>-
  • A vintage car parts shop here in Adelaide South Australia has several 1933 hub caps for sale, and also a mid 30s full size hubcap with the words Hudson8 on it. ozhudson@gmail.com
