1936 Terraplane 6-cyl motors
dholck
edited June 2013 in HUDSON
I have two 1936 date-coded 6-Cylinder Terraplane 'used' engines. One has a hole in the side, but I'm told these things can be fixed nowadays. The idea was to have these two engines to make one good, complete, motor (fan to flywheel, more-or-less). I got them from a hot-rodder, along with a 35 block, and the 35 block rebuilt OK and went into my 34 Terraplane Coupe, so these are sitting around. They are located about 100 miles NE from San Mateo (near Stockton, CA) and I could get them over to the National, if need be; or pick them up on your way home if you live east or north.
I'm still looking for an original air cleaner for the 34's Carter W-1 281S carb ...3-1/4 inch throat, if I recall correctly.
  • If your air cleaner requires a 2 3/4" dia. throat, I can help. These may be from 34-37 I really am not sure.
  • Are there so many 36 engines available that nobody needs any?
