in need of an original air cleaner for '35 t-plane 6cyl
hello, i have a '35 t-plane 212 cu in engine. i am in need of an original air cleaner/silencer for that car. my car is a 20 footer, but i continue to try to move it closer to stock rather than farther from stock. i have a very nice period air cleaner from a chevy but i would like a nice original if possible. thank you. regards, tom
Tom, I have several from that era . Don't know which years these Hudson/ Terraplane air cleaners go to but if you give me the carb air horn diameter I can see if I have any that match up.0
hello, thanks for the reply. the od of the carter carb throat is 2 1/4". there is a picture of the silencer/air cleaner i am looking for on the lubrication chart fold out in the '34-'37 mechanical procedure manual following page 4 section 2...bottom row of images. the chart is for 1936 cars.
thank you. regards, tom0 -
Sorry Tom. Nothing with that diameter. All were larger.0
thank you for checking. regards..0
I know I have several of those if you are still looking.0
just saw your post tonight..i did find one. thank you. regards, tom0
TM, you might try Carl Weber in Massachusetts. He has quite a bit of early-mid thirties stuff. Contact info is in the HET roster.0
Thanks Park. I did find one. Regards, Tom0
- 112 Hudson 1916 - 1929
