Singoe conductor 12v starter question
Unknown
Continuing the 12 volt upgrade of my 48 stepdown;
I have a 12 volt starter that I got off eBay. It's for a Hudson, and came with a generator and water pump for a 308. This all came off a Hornet, I think.
The starter that's in the car has 2 conductors. 1 goes to the battery, the other (solonoid) to the starter switch. This new starter apparently has an integrated solonoid, as it only has a single conductor. I think you give it 12 volts, and it actuates and spins. I'm told it's meant to be started by a floor switch (that can handle a zillion amps? :-) )
Can I take this thing apart and run the solonoid wire out to the switch? Or should I set up a high current starter switch somehow?
Suggestions?
Thanks;
-Chris
  • nick s
    nick s Senior Contributor
    after 1950 the solenoid was moved from the starter housing to the inner fender near the voltage regulator. you will need a solenoid in line with your starter button
    Suggestions?
    Chris ...
    Nick is correct ... the following website will provide you with diagrams for a Ford Tractor... do not dispair... the Hudson is the same as the tractor in most respects... check all the options out at this location...http://www.myoldfords.com/wire.asp
    This is the closest to the situation you are facing and it is a solution using the fender mounted solenoid recommended by NICK.
