NEW ITEM CARB GASKETS
PAULARGETYPE
edited June 2013 in HUDSON
AS MOST OF YOU KNOW I HAD NEW HEAT PLATES MADE FOR BOTH 1 BARREL AND 2 BARREL CARBS I WAS ASKED BY SOME PEOPLE TO CHECK IN TO HAVING NEW GASKETS MADE FOR UNDER OUR CARBS SO AFTER SOME HUNTING AROUND I NOW HAVE NEW GASKETS FOR UNDER AND OVER THE HEAT PLATES THEY ARE DUBBLE THE THICKNESS SO YOU ONLY NEED 5 TO REPLACE THE ORIGNAL 7 YOU HAD BEFORE ON THE ONE BARREL CARBS THE 2 BARREL GASKETS ARE STILL THE SAME THICKNESS AND WILL STILL NEED 7 THEY ARE ALL $2 FOR EACH GASKET
SO FOR A TWIN H YOU WILL NEED 10 GASKETS THEY COME IN SMALL BORE EARLY A1 CARBS AND W1A (WASP,PACEMAKER AND JET) 1 BARREL CARB AND W1A LARGE BORE FOR THE HORNET I BARREL CARBS
2BARRELS ARE $2 EACH ALSO THEY COME IN 2 DIFFERENT TYPES ONE FITS THE WDO CARB AND 1 FITS THE WGD
ALL ARE + POSTAGE OF $4
EMAIL ME IF YOU HAVE ANY QUESTIONS HETHUDSON1957@AOL.COM DROP THE HET OFF THE FRONT
OR CALL ME 412-855-6557
  • TRYING TO KEEP THIS ON THE FIRST PAGE
  • I am getting ready to go through my carbs, I just bought kits. I don't think these are included. If I need them I will contact you on Monday.
  • PAULARGETYPE
    edited June 2013
    WHAT EVER YOU WANT KEN YES I ALSO SELL A AIR CLEANER DECAL THAT LOOKS LIKE A HOT DOG IS THAT THE ONE YOUR LOOKING FOR? I'LL GET A PHOTO OF IT UP ON HERE IN THE MORNING
  • PAULARGETYPE
    edited June 2013
    KEN THIS IS THE AIR CLEANER DECAL THAT GOES ON THE STEP/DOWN OIL BATH AIR CLEANERS THEY ARE $5 EACH
  • HERE ARE THE OTHERS I STOCK YOU PICK WHAT YOU WOULD LIKE $5 EACH + $1 FOR POSTAGE
