Front Bumper Question For 54
HornetSpecial
Are all front bumper's the same on stepdowns 48 to 54 ??
Thanks, Paul in MN
Thanks, Paul in MN
The entire front bumper will interchange from 48-54,however different years had different styles of bumperettes as well as different numbers of them. {Pacemaker style could have two or four]. All use the same bumper retainer brackets and the mounting hardware was the same. The horescollar bumperette on the 51-53 front bumper is one of the toughest pieces to obtain in unmollested shape due to the design of that piece always taking the impact. Much as the 52-53 tailights always getting cracked.0
HornetSpecial wrote:Are all front bumper's the same on stepdowns 48 to 54 ??
Thanks, Paul in MN
Although the bumpers have exactly the same shape, the holes for mounting the bumper guards are different . Acording to the parts book ...... 48-49 are the same.PN 213512 .1950 is by it's self PN 220310 and the 51-53 are the same PN 225287and 54 is by it's self PN 225239. The outer bolt holes are the same. just the bumper guard holes are different. As usual I learn things the hard way. I had a 54 bumper on a 49 .In some cases you can redrill the bumper supports to match the bumper.
Have fun, Dave W Fl.0 -
the 54 bumper is a one only. they look the same and will bolt on but you cant use any other bumper on a 54, they curl up over the park lights. take it from experience,, BILL ALBRIGHT0
