Gas distribution on twin H carbs
Ray-
It doesn't make any difference how the gas comes in, as long as your float bowl is not running "out of gas", so to speak. You can't use up the gas in the bowl faster than it is being filled, even flat out. Nothing here to re-engineer that I know of.0 -
Thanks Russell Just an idea. Ray0
You can certainly route it the other way, I just don't think it makes a difference performance wise. In fact, I'm pretty sure the Hudson engineers routed it the way they did in order to get the fuel line as far away from the exhaust manifold as possible.0
That is a very good thought about the exhaust.I will leave it the way it is . Ray0
True , that's why the line is off in space like it is ,
Roger0
- 112 Hudson 1916 - 1929
