Front and rear vent window weatherstripping
Hi in the final stages of my 1949 commodore build last steps are the vent windows, side and front stainless trim, carpet, headliner, door panels, place the new ww tires on, and place the seats inside. If anyone knows of an aftermarket seal or pointers on how to remove the seals and vent windows it would be greatley appreciated as my interior is still stripped and empty.
The only seals you will find for vent windows is at Wildrick Rubber Parts. There is a hole in door panel below pivot on wing window . In there you find a bolt to remove that seperates window pivot from winder mechanisim. Then pull down off top pivot and remove . As I recall there are a couple screws on top of door frame to remove the rest of vent frame.
Roger0 -
Comm6, I have the Run Channels and the beltlines for the door windows and the division bars. $145.00 + shipping and handling.
VicTor Zamora
(562) 947-5864 Voice mail
Rodger does the whole exterior window trim need to be removed or is this just inside the door panel??0
Victor z the 145 is that for all four doors or just one?? Shipping is to Las Vegas NV.0
Yes, Comm,
All Four doors. Shipping $20.00 to 30.00 to Lost Wages0 -
Just inside door panel and window surround bezel,
Roger0
- 112 Hudson 1916 - 1929
