How do I remove these lenses
put on safety glasses an a pair of pig skin gloves take out the screw on the bottom of the light then take your time and push the lens in on the top I think it is and kind of roll it upward and the bottom of the lens should come outward and you can remove the lens .0
Rick
a very good piece of work you must have put a lot of time into that document
Steve0 -
Rick,
Very nice explanation. It was very smart using the edge trim for the outer ring. I have a set of buckets and bought these because I couldn't find a source for the rings. Thanks0 -
Boy, I need to start proof reading before I post!0
- 112 Hudson 1916 - 1929
