Wire for wipers
You can buy the cable at a good hardware store. take a sample.
You can use " stakOn" connectors for the ends.
A little less work and bother to install a used one new one.
But it is repairable.0 -
I have 2 or 3 pair of used ones. Gladly send what ya need for postage.
Kim
hethudsonbaker@myexcel.com, drop het.0 -
Please state year and model as Hudson had 2 set ups on the engine side of the fire wall. Walt.0
This is for a 52 hornet Its broken on the drivers side right where it goes thru the firewall. Thanks for your help. John0
Braided stainless cable is best, obtainable from boat repair shops. Used for connecting to outboard motor controls. I tried cycle cable, like on the hand brake levers, but it was too stiff.0
- 112 Hudson 1916 - 1929
