shim material for bearing caps
I've seen only steel and brass.0
They did indeed use alloy shims, but usually only the very thin ones.0
Thanks guys. I though perhaps the softer material may compress over time so I am surprised it was used. Learning something new all the time. Thank you. Tom0
Aluminum foil is about .0007 in regular gage and .0014 in heavy duty. Works great. And you can cut it with scissors.0
.0025" steel cuts easily with a fiskars scissors as well. I have done up to .006" steel too. Regards, Tom0
Over the years the materials that "ole time" mechanics used have disappeared. I still have a package of feather shims. You might ask, what “feather shims” are. My package contains a series of metallic sheets that range in thickness of the foil one would use to "leaf" a substrate, to that of thick cooking foil. My mechanic friend would use this graduated set of shims behind bearing shells to set clearance on cranks and rods. The "feather" was thin at one of the edges and thick at other. We used these shims last to bring a used set of Stepdown mains into the correct tolerances. When completed our back yard refresh resulted in a smooth running engine with lots of power and proper oil pressure. Proper use of shims or feather shims seems to be a LOST ART.0
Thanks for the post. Never heard of them. Regards, tom0
