More Hash 308 questions
Have a 308 out of unknown 55 or 56 (no engine number stamped on pad, single carb, twingroove pulley on balancer, was hydromatic)that I want to put in an early stepdown with 3spd OD. I know the mounting plates have to be changed, along with starter, flywheel and clutch. Is the crank ok for this application and will the pulley work? Eventually I'd like to put AC in the car. Any other issues I should know about. Thanks
Also need to know how to remove pulley/balancer? Is there a special tool required?0
Hi,--- You will need at least a 2 jaw puller to remove the vibration dampener after the large nut has been removed.0
There are bolts in the back of the balancer, leave them in I take it? Thanks0
boothguy wrote:Have a 308 out of unknown 55 or 56 (no engine number stamped on pad, single carb, twingroove pulley on balancer, was hydromatic)that I want to put in an early stepdown with 3spd OD. I know the mounting plates have to be changed, along with starter, flywheel and clutch. Is the crank ok for this application and will the pulley work? Eventually I'd like to put AC in the car. Any other issues I should know about. Thanks
You need early oil pan, also.0
- 174 The Flathead Forum
- 599 Vehicles
