RUBBER TRIM SEAL ON FRONT OF DOORS
Is there anyone reproducing the 1/2" wide rubber seal that goes on the front vertical edge of the doors (just guessing 25"-30" long) on my 52 Hornet? When you shut the front door it seals against the fender and the rear door has this seal also. It has the metal clips in the original but I think you could just use a closed cell rubber strip and glue it in.
Thanks, Bill
Thanks, Bill
Of course! Contact Wildrick Rubber Parts for all you Hudson rubber needs:
http://www.wildrickrestorations.com/wildrickrubberparts/wrp.html0 -
K-gap used to sell what they claimed was to be these parts but when I got them they were just strips of foam rubber. I hope Wildrick has a better reproductions.0
You should try them. I am sure you will be most pleased with the quality of parts and the quality of service.0
I will give Doug a call on Monday. Thanks guys0
Can sell you what you need for $35 with shipping,
russ maas0
- 112 Hudson 1916 - 1929
