foam seal install
I am trying to figure out how the foam seals #153 from Kgap is glued on.Front door vent frame/
body seal on windshield pillar. Or # 137 Front door vertical seal. For a 54 Hornet Hollywood.
Could you please explain or post pictures of proper install . Thanks Ray
Could someone please post a picture of the drivers or passenger windshield header seal that seals the vent window against the post. 54 hornet hollywood or conv. Ray0
Will cpe pics do Ray?0
Sorry Dave but coupe picture will not work. Your outside of door has the seal glued to it. Our Hollywood the seal is glued to the windshield post.Maybe I have the only 54 Hollywood.
HEHEHEHE just kidding. No replys yet except for you. The 54 Convertable is the same door as our hollywood. Ray0 -
Ray: I have posted some pictures that I hope will help you determine where the seal is affixed.0
Thankyou Oldfarmer The pictures are great but are not close enough for me to see what I need to see,
. Could you take a real closeup picture of the drivers side door above the top hinge to under side of roof where headliner is held in place .From front of windshield post to rear of quarter window. Thanks so much. Hudsonly Ray0 -
The pictures are of other folks cars. I used MS picture viewer and increased image size on each before posting. The clarity of the pictures get a little fuzzy but the seal location can be seen for the front vent window seal. The seals for over the door at located by closing the door and marking where the top of inside the window comes into the body. This located where the seal edge should rest when installed.0
Thanks for your help Ray0
- 109 Hudson 1916 - 1929
- 176 The Flathead Forum
