54 Hornet 308 Engine Correct Serial Number?
[Deleted User]
Hello Experts,
Is 308 engine serial number 189010 the correct engine for a 54 Hornet? Thanks, Niels
  • dave s
    dave s Senior Contributor, Moderator
    1954 Hornet starting serial number is 7269066. That is probably 1952 engine
  • Daves right, probably near the end of the 1952 model run.
    So it is not the original engine in a 54 Hornet Special but one could call it a "correct" engine? Also, did the 54 engine serial #s match the car serial number? Thanks, Niels
  • hudsontech
    hudsontech Senior Contributor
    Engine and car numbers were the same from mid-1938 up.
    Alex B
  • nick s
    nick s Senior Contributor
    an origional 54 hornet block will start with a "7".
    they must have ommitted the prefix in 52?
