54 Hornet 308 Engine Correct Serial Number?
1954 Hornet starting serial number is 7269066. That is probably 1952 engine0
Daves right, probably near the end of the 1952 model run.0
dave s wrote:1954 Hornet starting serial number is 7269066. That is probably 1952 engine
So it is not the original engine in a 54 Hornet Special but one could call it a "correct" engine? Also, did the 54 engine serial #s match the car serial number? Thanks, Niels0 -
Engine and car numbers were the same from mid-1938 up.
Alex B0 -
an origional 54 hornet block will start with a "7".
they must have ommitted the prefix in 52?0
