Need a few more numbers for brake parts.
jjbubaboy
edited November 2013 in HUDSON
Got the shoes, bearings, races, seals and cylinders. Looking at it might as well complete it so...
looking for part numbers for the springs, (hold down, return, and bottom adjustor), the adjustor itself, and if their is a
combo kit for it. 36T by the way.
Thanks,
Jeff
  • Look at Rockauto.com under Hudson 1947 Super Six. These brake parts are the same. The only difference is in the cam hole for the secondary shoe, which you can lay out and drill. Been there done that.
  • Thanks Uncle Josh.
    I did and they only list some of the parts and they are for 11" drums and mine are 10"s.
    Didnt find correct adjustor and spring yet tho.
    Jeff
  • 6 cylinders are 10 inch. 8 cylinder and pickups are 11 inch
  • Thats what I figured Josh.
    Gonna go ahead and order the parts and see what I get.
    Thanks all.
    Jeff
