in need of an original air cleaner for '35 t-plane 6cyl
tigermoth
edited June 2013 in HUDSON
hello, i have a '35 t-plane 212 cu in engine. i am in need of an original air cleaner/silencer for that car. my car is a 20 footer, but i continue to try to move it closer to stock rather than farther from stock. i have a very nice period air cleaner from a chevy but i would like a nice original if possible. thank you. regards, tom
  • Tom, I have several from that era . Don't know which years these Hudson/ Terraplane air cleaners go to but if you give me the carb air horn diameter I can see if I have any that match up.
  • hello, thanks for the reply. the od of the carter carb throat is 2 1/4". there is a picture of the silencer/air cleaner i am looking for on the lubrication chart fold out in the '34-'37 mechanical procedure manual following page 4 section 2...bottom row of images. the chart is for 1936 cars.
  • Sorry Tom. Nothing with that diameter. All were larger.
  • thank you for checking. regards..
  • I know I have several of those if you are still looking.
  • just saw your post tonight..i did find one. thank you. regards, tom
  • TM, you might try Carl Weber in Massachusetts. He has quite a bit of early-mid thirties stuff. Contact info is in the HET roster.
  • Thanks Park. I did find one. Regards, Tom
