35 update
dterry-2011
edited November 2013 in HUDSON
Two years now, it is plated, brakes adjusted correctly, front end lined up sterring box repacked, rebuilt Carb, waterpump, oil pump, new u-joints, plugs, wires, coil, had the original gas tank rebuilt, waterjacket. Still needs a clutch but I can run her around the neighborhood to get my strange look fix. New tires including the spare. Body needs PLENTY of work. Vin 5130124 also stamped on front axle and frame. I think the rear axle replaced at some point. Last time registered before me was Idaho 1962
