'51 Pinion Seal #
What is a good part number for a 51 rear end pinion seal? I have several numbers scratched on my notes and I can't figure out which was which. I do know there were three different ones for the Hudson built rear. I have a carrier assembly on the way from Texas Via UPS. I want to replace the seal before I install it. I did this same thing about five years ago... I let my mind wander and it never came back...
Thanks in advance, Dave W. Fl.
NAPA 177200
Went to carquest and got their cross over..710005 Works prefect.
National 5778 Nitrile material, 5778V Viton material.. Also 99105 pinion repair sleeve if the yoke surface is scored.0
