Chrome Trim Removal Help - '54 Jet
If its the polished stainless drip rail moulding you are referring to, I had good luck on my Hornet with a soda bottle cap opener with masking tape wrapped around it. Everything else trim wise is a friggin nightmare.
Best method to take the body trim off is to have a pry bar, and something like a plastic or steel rule to go against the body to lever against. Lever only one side off, don't try and peel it off both sides at a time or you will distort the trim.0
soak with penetrating oil first. Rust build up on the rails makes it difficult0
A vinyl siding removal tool has a tiny j channel hook on the end which can be slipped under the molding, catch the molding, and GENTLY pry the molding outward and off the retainers. DO put something under it (spackle knife, mult layers tape, etc) against paint to save the paint.0
I have used the "RED Devil" paint scraper to pry the trim. Good for straight lengths. Needs a backing
board to avoid damaging the paint.
I also used a bent red devil scraper once started just tap with a hammer lengthwise. Use lots of lubricant. Good luck
I may be a little late to the party, but since I need to pull my stainless to paint my 54 I stopped by Harbor freight today and picked up a few small pry bars. They run about a buck each and since they are low quality stuff, I can grind them to what works for me. I bought four.... Just tried one and it works great and does not damage the stainless....0
Brownie, Any pictures of how you ground yours to get the trim off.
Thanks,
Larry
So I went out to the shop and gathered up all my stainless removal tools and took a photo. So, here you are--by the way, I sharpened them before I took the photo....... By the way, no one tool works better than the other. My rule is the smaller the tool the better it is to start with/0
Thanks, Brownie
- 109 Hudson 1916 - 1929
- 176 The Flathead Forum
