LAST CALL FOR AXLE BEARINGS
PAULARGETYPE
THIS WILL BE THE LAST CALL ON THE CHEAP PRICE ON WHEEL AXLE BEARINGS I HAVE A FEW PEOPLE WHO EMAILD ME SAYING THEY WANTED BEARINGS AND HAVE NOT SENT PAYMENT SO THE CHEAP BEARING SALE ENDS AS SOON AS THERE ALL GONE IF YOU ORDERED THEM SEND YOUR MONEY BECAUSE NOW IT IS 1ST COME 1ST SERVED IF YOU PAY BEFORE THERE ALL GONE
THEN SAD TO SAY I'M SORRY THERE ALL GONE
I'll purchase one if there are any left.
Thanks!
Dan
Paul,I will take another set. I will send you a separate email.John ForknerSpring Hill, KS0
THE BEARING # IS 25877 T THEY ARE MADE BY SKF THEY ARE $33 EACH WITH $5 ADDED SHIPPING IF BUYING 3 OR LESS AS BEFORE SEND ME A EMAIL WITH YOUR NAME ADDRESS AND HOW MANY BEARINGS YOU WANT THEY FIT 1936 TO 1951HUDSONLYPAULARGETYPEMY EMAIL XXXHUDSON1957@AOL.COM DROP THE XXX IT'S JUST THERE FOR THE SPAMERS0
Be sure they have the "T" in the number. The number is the same for both, but without the "T" it is not the tapered bearing that a Hudson requires.
The 25877T that Paul has found and is selling is the correct Hudson bearing.
The 25877 that is avail everywhere for very cheap is NOT the correct bearing.
The race for the 2 bearings are the same.
The Hudson used a tapered axle shaft so the ID of the bearing had a corresponding taper to match, which is noted by the "T" in the part number suffix. All this information was covered in previous bearing threads here in the forum.0 -
The parallel-bore 25877 bearing is for the later stepdown Dana diffs?0
YES BOB THAT IS RIGHT0
THE WAY I INSTALL A NEW BEARING ON THE AXLE IS PUT THE BEARING ON THE AXLE AND WITH A BLOCK OF WOOD ON THE FLOOR DROP THE AXEL ON THE BLOCK OF WOOD WITH THE TREADED END DOWN AND IT WILL JAM THE BEARING IN TO PLACE NO PRESS NEEDED I'VE BEEN DOING IT THIS WAY FOR YEARS ;-)0
I'll take 3, I've sent you an email.
Thanks
I HAVE 16 LEFT AFTER ALL THE ORDERS HAVE BEEN FILLED LAST CALL !!!!0
I've not gotten an email back from you, I've sent one to you. Thanks
I sent you a pm let me know that you got it thanks.0
G'day All,
I presume that the 2788T without the inclusion of "5" is a different bearing
The 2788T is used on the 4 stud hubs
Just in case, thought it worth getting confirmation that Pauls "5" bearings will not fit in lieu.
Thanks
Phil
Australia0 -
PHIL NO THAT IS ANOTHER BEARING THESE BEARINGS I'M HELPING US ALL GET AT A STEAL ARE 25877T THEY ARE TAPERED INSIDE BEARINGS FOR HUDSON REAR AXELS THEY ARE THE REAL DEAL THESE BEARINGS FOT 1936 TO 1951 HUDSON CARS0
Hi Paul
If you still have four 25877T bearings I will buy them. I have sent you a PM with my email address but have not heard back from you
Thanks for making the bearings available.
Lee O'Dell0
- 110 Hudson 1916 - 1929
- 177 The Flathead Forum
