stepdown head bolts
[Deleted User]
edited June 2014 in HUDSON
Where can I get pre 55 big six head bolts ? 7/16 bolts that use a 3/4 spanner.
  • Randy Maas 309-267-6158
  • Dale Cooper is also a source of Hudson equivalent new manufacture head bolts.
  •  Big Paul has these.   He sent me a set.   Bolts and hardened washers.
  • PAULARGETYPE
    edited June 2014
    THE 7/16 ONES I SELL HAVE 11/16 HEADS NOT 3/4 BUT WITH THE HEAVY WASHERS THEY WORK GREAT AND THEY ARE ONLY $25 FOR ALL 21 BOLTS WITH THE WASHERS ALSO THE BOLTS I SELL ARE ALL GRADE 8 BOLTS
    JUST A NOTE IF YOU HAVE OFF YOUR HEAD FOR ANY REASON LIKE CHANGING YOUR HEAD GASKET MOST LIKLY THE BOLTS HAVE NEVER BEEN CHANGED BACK IN THE DAY THEY DID NOT HAVE GRADE 8 BOLTS THEY ARE MUCH BETTER THAN THE ORIGINAL BOLTS AND HAVE NEVER SEEN A  GRADE BOLT BREAK OF STRIP
  • Dale Cooper sells a high quality set of head bolts, washers, and whatever else you need.
