Fuel issue?
Commodore_254
I have a 1951 Commodore 8 with the 254. In the beginning of June I drove it from Joliet to Indianapolis for the Good Guys car show without any issues. Three weeks ago I drove it and and my wife who was following me said it's smoking like a freight train. The weather here in Chicago area is finally dry and my car sits in the garage!!!
After a night of test drives and adjustments I accidentally left the key on and fouled the iginition points. I have since cleaned the contacts, reset the gap (dwell) and reset the timing. My dwell angle is a little low, 21 when it should be about 27 degrees.
The smoke is whiteish and is constant (start, idol, acceleration). It smells like unburnt fuel. What do I do next?
Your indication of "white smoke" is most likely a coolant leak into the combustion chamber.
A way to ID if this leak is into the combustion chamber is to pull
Radiator cap, start and warm car. Look
Into the radiator filler neck and if you see a steady stream of bubbles accelerate the engine to see if more bubbles occur. More bubble = combustion leak. White smoke = coolant leak into combustion chamber.1 -
Agreed. Fuel is black, oil is blue-gray1
Also the smell will be " sweet" if you have antifreeze in system. Most likely head gasket.
Try retightening head bolts first
1
- 96 Essex Super 6
