Lower rocker panel and tri angels 52 hornet
2 triangles? Can you be a little more specific?0
Are you taking about the two stainless pieces that go on the rockers? Larger one and smaller one?There are three different lengths. The rocker panel, the fender skirt, and the small rear rocker panel.0
Must be bull islander. If that's the case, then good used rockers with good stainless attached, all 6 pieces (long rockers, fender skirts and rear corner pieces) could go anywhere from $100 to around a grand.
"Rims" or wheels, if that is the case are usually $25-$75 a piece depending on condition, size, etc.0 -
Thanks for the call back, Have to jack it up It in weed 6 to 8 in. tall . I know the floors are gone. did not feel like laying in the weeds, Ill bring my mask and tools and see what is . Thanks John0
Let us know how it turns out. Remember, the rustier (i.e., cancer) it has, the less value it should have as it takes more $$ to repair.0
